Matador
Here is an apparent schematic of (one of two channels) of Mesa Boogie's 'Simul Class' 90 watt power amp. Their description claims that of the 4 output tubes, two run in class AB and the other two run in class A, hence 'simultaneous class' (both A and AB at the same time):
I can't for the life of me figure out how this is working as advertised. The inner pair is grounded cathode, with a standard 1.5k grid resistor, and 470ohm screen resistor, connected to the inner taps of an ultra-linear power transformer, with a fixed bias of about -55V. The outer pair appears to have a resistive divider at the grid that reduces the fixed bias voltage down to about -42V, and the screen grid resistors are 2.7k instead of 470 ohm, and they connect to the outer windings. Cathodes are grounded like the other pair.
How is this output tube set biased in class A? As near as I can tell, the bias is certainly 'hotter' in the outer pair by 7-10V, but this would not cause the tubes to conduct for the entire 360 cycle as is required in class A, as a significantly 'higher' bias voltage would be needed to ensure the tubes both conducted for the entire input cycle.
Am I missing something obvious here?
![2901.gif](https://proxy.imagearchive.com/93e/93e390db89dd53a81b81f3882d4ebbae.gif)
