JMPGuitars
- Joined
- Apr 30, 2018
- Messages
- 152
I just completed my U47 408A build. I decided to post this thread to share some photos and such using Poctop's D47 circuit boards, as I wasn't able to find a good thread on the subject with the current boards.
Here's the mic PCB:
I marked the foil directions in case anybody is into that kind of thing.
Capsule connections:
I used thermal paste and mounted the the 1.5K heater resistor at the base. To fit in Chunger's U47 body, I cut off one of the mount arms and drilled a 1/16" hole in the base. Note: in case the heater wiring on the mic PCB is confusing, that's where the 2 ends of the 1.5K resistor get connected.
The PSU PCB:
Poctop was concerned with heat from the pot being on the board, but I have a thermal camera and ran some tests. I'll share the photos/info in another post, but the result was that I'm not concerned about the heat.
Here's my completed PSU. I didn't use a lighted switch instead of the LED method. No concerns with current draw at all that way.
More photos of the finished mic:
Here's the final mic and PSU:
Here's some useful information for the build:
Wiring the Mic:
Pin 1: Green (B+)
Pin 2: Yellow (Pattern)
Pin 4: Blue A- (XLR 3)
Pin 5: Red A+ (XLR 2)
Pin 7: Black (Ground)
I wired the PSU following the same scheme as the mic.
Mic Cable:
Pin 1 Red
Pin 2 Grey
Pin 3 Yellow
Pin 4 Black
Pin 5 White
Pin 6 Green
Pin 7 Blue
I used Gotham cable, with the heavier gauge Blue/Red wires, which I placed at Ground and B+. Some people choose to only wire the 5 pins that are used in the mic. I also wired pins 3 and 6 because I didn't want the cable to be limited to only this mic. (Note: I used the heavier gauge wires on B+ and Ground because the heaters are run off of there via the 1.5k resistor.)
Calibrating the PSU:
It's really simple. Place the jumper in the test position on the PSU PCB, and use a pliers to turn the knob to dial in 105VDC. You can attach your meter to the Ground and B+ test points on the PCB.
My Voltages:
Mic:
Heater: 37.4VDC
Cathode: 1.23VDC
Voltage Divider: 55.4VDC
Before C2 Output Cap: 44.3VDC
PSU:
B+: 105VDC
Cardioid: 48VDC
Omni: 50.4VDC
Note:
My T47 transformer is mounted on the opposite side of the PCB so that it would fit properly in the mic body. Since both sides of the transformer are run in series, it doesn't matter which side of the PCB it's mounted on as long as you don't confuse primary/secondary sides of the transformer.
I found this to be an exceptionally straight-forward build. I'm looking forward to hearing this after I burn in the tubes for a few days. I may tweak C2 on the mic as Poctop said he heard a big difference changing caps there. However, I'm a big fan of the Mallory 150M caps I used on this, so I'll see how it sounds before I bother tweaking anything.
Josh
Disclaimer: I'm not commercially interested in this, or being compensated to post this in any way. The mic is not for sale.
Here's the mic PCB:
The PSU PCB:
Wiring the Mic:
Pin 1: Green (B+)
Mic Cable:
Pin 1 Red
Pin 2 Grey
Pin 3 Yellow
Pin 4 Black
Pin 5 White
Pin 6 Green
Pin 7 Blue
My Voltages:
Mic:
Heater: 37.4VDC
Cathode: 1.23VDC
PSU:
B+: 105VDC
Cardioid: 48VDC
Omni: 50.4VDC
Note:
Josh
