Need advise about FPC / FFC cables and connectors
JAY X
For my next project i will need to use FPC connectors like the one attached in this message. It is a 24 contacts FPC connector by MOLEX, with two rows of pins. I know that there are FPC connectors with 1 or 2 rows and 0,5 or 1 mm pitch, with connector at one side or another or both sides like this one. The problem I have, is to select the right 24 wire FFC cable with the correct pinout at both ends, and both sides of the cable, to match the connector pinout. Will they match?:unsure:
Thank you for your help!
Jay x
MOUSER REF FFC CABLE: 710-687724152002
https://www.mouser.es/ProductDetail/710-687724152002
MOUSER REF FPC CONNECTOR: 538-501951-2400
https://www.mouser.es/ProductDetail/538-501951-2400
  • 5019512400_sd MOLEX FPC VERTICAL BOTH SIDES.pdf
