Neve LO1166 gapped transformers
Spencerleehorton
Felixstowe, Suffolk, UK
Had some EI75 lams sitting around so I thought I’d build some LO1166 gapped output transformers.
Specs wise they come out as per original winding sheet with a little more inductance which is nice.
Pri A - 9.2R (80mh) Pri B - 8R (80mh)
Sec A - 21R (220mh) Sec B - 21.2R (220mh)
Will test them in a Neve 1290 and a 2254.
Have built 5 pairs so far.
Not varnished yet and still need to trim the bolts as they are a tad long.
Used an I and slotted the turret board, took your advise as well CJ with clamping the I to the E then securing all the bolts, made my own bobbins which turned out well.
Very happy with them so far and they fit inside a 1U as they are only 38mm wide.
It’s in the tech docs section under Neve
Sec B should be 0.010” (0.25mm) gauge rather than 0.033”(0.314mm).
Winding what it says on there ends up being only 14ohm on the sec B and needs to be 21 ohms same as sec A.
Masking tape measures about 0.7mm
Looks nice! Do you know the manufacturer of the laminations? Are you happy with the inductance value? Can you measure it?
