New cheap 12bit scopes from Rigol
Looks pretty nice, but those models are not listed on the US site and they have not returned any emails about availability.
I think they’re shipping mid October.
Hopefully this means Siglent will also release a budget 12bit scope soon…
I bought one of these a few months back for field work. i.e when visiting clients by train or air.
https://www.owon.co.uk/product-page/hds272s-70mhz-handheld-oscilloscope-with-signal-generator
Whilst it may not be the ideal scope for bench work in my workshop, it is brilliant for on site work being dual trace & having a signal generator. I was travelling up to London etc on public transport & trying to fix stuff on site with no scope at all & this has just made things a lot easier. I got it in a deal from Allied Express for something like £130 U.K. In reality for most jobs in the workshop it would be adequate too.
One particular advantage is that being battery operated you can strap it straight across a balanced line without having to warry if you are accidentally grounding one output.
Nice find.
That looks pretty cool. How's the build quality?
This is definitely a newbie question, since I've only been using a scope for a year or two, but what is the practical advantage of 12 bit when using a scope for audio circuits? Does it let you use the scope in a different/better way than a lower bit scope? I've been using a GDS-1054B but I probably only really use like 5% of its abilities. Anyways, just genuinely curious.
I think I have seen similar looking scopes on AliExpress with much lower pricing, i may be mistaken! I'll be looking again!!
Not a huge practical advantage. The noise floor should be lower, so you might be able to see a small signal superimposed on a larger signal which would be difficult to see with an 8-bit scope, or the noise floor of an FFT of a signal should be lower.
You should be able to live with an 8-bit scope just fine if that is all that fits your budget.
