Dimitree
- Joined
- Jul 26, 2011
- Messages
- 120
I started this new project: a small and simple console for my bedroom studio.
I'm seeking advices and corrections about the concept, since I'm not a beginner when talking about recording studio workflow.
I have several synthesizers (most of them DIY by me) and other electrical instruments (guitar, bass, e-drums), so my main needs are:
- not to be forced to use the computer + soundcard every time that I want to play (monitor) all those instruments
- share my outboard effects between multiple instruments without having to plug/unplug all the connections every time
bonus:
- using the console as a summing mixer, to get the benefits of faders/knobs in terms of ergonomicity, and why not, even in terms of sound (if I decide to use a particular summing stage)
Also, I'd like to point out that I only use my "studio" for myself, I don't intend to record other people, and the console will be placed in the same room as my instruments, that's why many facilities of the bigger consoles won't be on this (foldback, talkback, etc).
so this is my idea of how a single channel could be (I think it will have 16 mono channels and 6 stereo channels).
Since I don't need preamps, EQs and Dynamic processors (I will use them as outboard when needed), the entry points would be two simple line inputs (with +/-20dB trim on each input).
One input would be used by the instrument to be monitored/recorded, the other will be used as return from the DAW. A "monitor" switch will select the input, so for I should be able to monitor, record, overdub and mix, just flipping those switches on each channel.
A direct output is provided so that I can record the channel (either after the line input or after the insert, if I want to record the outboard processing too..).
There will be both PFL and Solo-in-place. The former will have its own bus, so when active, the console output will switch from the main bus to the PFL bus. The latter will be used to hear the channel in the mix with pan and effects, so when active, every other channel will be muted, and the soloed channel (or channels) will still be routed through the main mix bus.
I think there will be four stereo Groups, and four mono AUX sends.
Every AUX will be connected to a pair of bus (using a stereo potentiometer) so that in the master section, globally for each AUX, I can choose it to be PRE or POST fader.
I still haven't decided if there will be Stereo returns, or if I will just use Stereo channels for the returns (little difference I guess, it comes down to deciding whether to put a fader or a potentiometer for the return level).
Same for the Groups, I still haven't decided if I will put a dedicated channel strip for each of the 4 groups, or if I will manually patch the output of the group into a stereo channel input whenever I need to use a group.
Lastly, a pair of momentary push buttons will be connected to a microcontroller and be used to control some DAW functions (channel select and REC arm). In the master section there will be other "digital" buttons for other DAW functions (Play, Stop, etc). I mainly use Ableton Live as DAW.
I haven't thought about the master section yet, but as I said, I think it will be really simple, because I will just use the console for myself. So I think a pair of stereo outputs (for the monitors and for the soundcard ADC) and an headphones amp for when I need to play late at night and/or record with microphones
bonus:
