taking a break now...will throw out some guesses etc.
it has been mentioned before that deriving yer fantum from the b+ is a bit riisky; maybe not a worry for chinois condensers but i'd think twice if i had any kraut mikes... there is a chance of b+ showing up at the xlr if something inside lets loose.
I'm not totally sure if this is the right place to discuss the circuit of the MILA rather than the building. If there's a MILA theory thread please redirect me!
* why use 100k pot and 1uF cap at C3 and VR1, why not use a 470k or 1M pot and a smaller cap?
I don't know, exactly, guess better bandwidth and frequency response. output z of 1st stage can drive 100k cleanly.
* does a 270 ohm grid stopped resistor really do anything much? obviously it must but what is the -3dB frequency for this? (I'm used to guitar amps and 68k grid stoppers)maybe, not as much gain as a marshall,not as prone to amplify noise/oscillate as a guitar amp but GS is a habit/potentially helpful* has anyone built this toplogy with a different valve in either or both positions? seems to me with appropriate changes for bias etc it could work with 12at7 12au7 or even 5670 in the first pos.
plugged in different valves, they work/pass clean signal but not optimal
The motivation for asking is that my intended PT is only rated for 1.5A heater and 4x 12av7 for 2 channels of MILA will draw 1.8A - do 12av7 actually draw 450ma each in reallife or do they vary with diff brands etc? OTOH the HT draw will be much less than the transformer is rated for, so maybe it will cope...try it, play the tolerances, if too much I then rebias for a 12__7 with lower draw* what is the best 12AV7 to use? I have heard the RCA is the best , and have ordered some of those, but would like to know other peoples experiences.telefunken or nos mullard ...seriously, ones from canadian-made color tvs...whatever
* why does the MILA use a 1uF cap in the feedback loop, but the NYD one bottle (which is closely related) needs 22uF? I presume its to do with the maximum NFB applied in the one bottle being higher (ie lower gain achieved through NFB)
Z. impedancses*has anyone used the MILA without an output transformer? i presume it would be fine into 10k loads since the output tube is paralleled from the onebottle and so is presumably approx half the output Z. is this right?
less than half Zo, will be fine*i'm thinking of using a lundahl 1538 1:5 input transformer, i guess the lower gain would make up for the higher gain at the other end from not using an output transformer, but is there any disadvantage to running lower levels through the whole circuit? I'm thinking levels vary much more than this anyway with different mics etc.
should be fine, noise,s/n may not be optimal, but 'twill work fine...if no need to drive heavy load, this maybe is not the best design/overkill. if yer power trans can do 4 filaments you could build 4 1-bottles. 1+ mike 1+ hiz cascadeable stages for dirt ,
