Hello,
I have the chance of buying an Audio Analyzer for a good price.
It's this unit
What do you think?
Are these type of units still useful nowadays?
There's a lot of people using software for measuring and are quite happy with the results, some people even use the REW software that is free and love it.
Is there anything I can do with this unit that I couldn't do with a system software based?
Thank you so much
Bellow you find some descriptions of the unit:
Audio Analyzer
For setting up and testing Analogue audio equipment, Such as Tape Decks, Turntables, Pre-Amplifiers & LF-Amplifiers This unit has had little use and is in good working order,
Can be used for speed & wow & flutter & azimuth tests on tape recorders, Power output tests on amplifiers.
Has built in frequency generator, 315, 400,1k, & 10 K Hz, Distortion Meter, Stereo A.C. Millivoltmeter, Stereo Wattmeter-20 to 2 watt @ 4 Ohms
External Output for Monitoring with Oscilloscope & Frequency Counter
The AA-930 has been designed to facilitate the repair, tuning and analysis of audio frequency equipment in general, such as cassette recorders, record players, radio-cassettes, preamplifiers, low-frequency amplifiers, etc. That is why six measurement instruments that are indispensable in an audio service workshop have been combined in one piece of equipment
The AA-930 is equipped with RCA 600W and DIN 47 kW connectors for the inputs and outputs. In addition, two BNC connectors on the front panel and two RCA connectors on the rear panel allow the user to view all of the signals measured by the instruments
LF Generator - This produces the most needed frequencies for the checking of sound equipment (315Hz, 400Hz, 1kHz and 10 kHz)
Stereo Watt Meter - With two sensitivities, 20W and 2W on an internal impedance of 4W, it measures the output stages in car radios, cassette recorders and radio-cassettes
It's this unit
![fIsrMWK.jpg](https://proxy.imagearchive.com/35f/35f887222ebed15ea23e8c7e56831737.jpg)
![DPxSaNu.jpg](https://proxy.imagearchive.com/9f9/9f95028f79b7202f84785a0b113c67d6.jpg)
What do you think?
Thank you so much
Audio Analyzer
