Cqwet Dbdfte
- Joined
- Oct 2, 2023
- Messages
- 406
Passive RIAA, sounds good. No feedback, fixed bias via LEDs. Tube loads are taken from "top" of current sampling resistors, avoiding load currents in the sampling.
Input triode connected pentodes running at 20mA, their gain is dependent on selection typ 85, some as high as 93. With low-ish plate supply I still can can get 11 V p-p, so any clipping would be in the next stage, gain of 33. The -3dB point of input stage is around 140KHz.
The 1KHz gain about 50dB. MC transfomers add another 27dB.
The beast pulls 23W out of the wall :-o
The current regulators are using LM431 types. Their gain varies widely between mfg's. The LT's part has the highest gain by a fat margin. Output noise is sub 10 Hz dominated, and around 1.5 mV unattenuated.
