clintrubber
Hello,
In short, the actual question is whether a quartet of powertubes with one current-greedy member
can result in undesirable effects (in a push-pull power stage) for the output transformer due to the unequal current draw?
I guess not, strong bass-notes might have a comparable effect, but just wondering...
The longer version, and something about screen-grid resistors:
I got hold of an old Peavey Classic 50 (the 410 version) with (4) EL84 / 6BQ5. Sovtek.
Knowing this amp is fixed bias ('twofold': negative grid voltage, and non-adjustable, no cathode resistors),
I wanted to know the currents per tube.
Using insert-adapters for measuring the cathode-currents, and re-measuring over time,
I found (3) stabilized around 25...27 mA each, and (1) of the quartet
persisted on drawing around 40...42 mA regardless of which socket it went.
(I didn't measure the plate voltages yet, but I understood the 25 mA is the intended ballpark figure in this amp.)
OK clear, not (longer) a fully matched quartet. So replace with a fresh matched quartet, case closed.
Amp sounds fine though, and as long as eventual damage is limited to just wearing out that 40mA tube faster
then the replacement is not needed any minute... as long as when it fails, it doesn't cause other trouble.
In addition, I saw not all power-tubes are treated equal in this amp, circuit-wise (see attached part of schematic).
To my surprise not all tubes have their own screen grid resistor.
There's only R46 & R55 for V4 & V5, but V6 & V7 don't have any 'of their own'. False economy ? Or OK ?
Thanks/Bye,
Peter
Thanks/Bye,
Peter
