rkn80 said:Hardware done. Testprogram (blinking LED) programmed and working. Now let's see wether we can communicate via USB. 8)
rkn80 said:Again some news:
The configuration has been changed to UAC2 and the host (MacOSX) accepts the device as a new sound card. 8)
I'm now finding out how the feedback mechanism for async. endpoints works and how the feedback values should be calculated. This is not clear to me, yet. I think I have to send the value per micro frame and not per frame as in UAC1.
R.
mhelin said:"In order to use implicit feedback, the device must satisfy the following requirements:
* Asynchronous input and output streams reside on one engine (i.e. needs to meet criteria for the Unified Engine Model.)
* The polling intervals (bInterval) for the stream endpoints must match.
* Either the input stream endpoint “Usage type” is set to “Implicit feedback data endpoint” (USB Audio 2.0 only, Section 4.10.1.1) and/or the sync feedback endpoint is omitted (see Table 4.)"
Omitting the feedback endpoint sounds quite easy.
Yes.chartanm said:... 1 I2S channel is 2 analog channel right ?
Well, let's be clear. You are talking about High Speed USB.1) Maximal number of audio channel onto USB
According to the link below, 1 analog channel @ 16x48k uses 0.5% of the bandwith of the USB. So, 1 channel (24x192k) is 3%. So we can put up to 33analog channel 1 one free USB ?
Remember that the stated "bandwidth" of 480 Mbps is really the wire speed; for high-speed transactions even one audio channel is still packetized and serialized at that 480 Mbps rate.But ! USB (High Speed) is 480Mbps, and 33 channels (24/192k) are only 33*24*192000 = 152064000 = 152Mbps ... so in fact we cant put much more than 33 analog channel !
Which way of thinking is wrong ?
(I need to precise that I know USB maximum bandwith is divided by the number of connected devices, but let's say that I a one completely free USB ... on a PCIe card for example).
2) Number of endpoints
According to the link I gave you, there is up to 16 endpoint on an USB device ... and there are normally 3 obligatory endpoint (2 for control and 1 for feedback).
It remain 13 endpoint, each one have an I2S channel, that made up to 26 analog channel !
Now check your math. 192 kHz times 24 bits per sample is 4.6 Mbps per channel.
For example, just to see if I understand well ... UART is 115,2bps (it could be more or less, but it is an example). So, I can send 115200 bits for control, redundancy, error check and data in 1 second. The amount of each is defined by the protocol I'm using on this serial link.Remember that the stated "bandwidth" of 480 Mbps is really the wire speed; for high-speed transactions even one audio channel is still packetized and serialized at that 480 Mbps rate.
The point being that only one OUT endpoint is needed for ALL of a device's DAC data, and only one IN endpoint is needed for ALL of a device's ADC data.
chartanm said:Hi,
Ok ... Good new ... I'm not so stupid, I understood (a few) things !
Yes, 1 channel is 4.6Mbps so 33 are 152Mbps. Remember, the link said that 1channel 16@48k is 0.5% so 1 channel 24@192k is 3% so according to this we can put 33 channels on an High speed USB.
What I wanna show you is that -even with 99 (3%*33 channels) percent of utilisation according to the link I gave you- it "remains" 480-152 = 328Mbps. So ... I understand that there are the control endpoints ... put if they uses 328Mbps of the bandwidth ... there is a problem no ?
Now, USB is 480Mbps. How many channels can-I put in one USB link ? There are 2 control enpoint (1 in and 1 out if i read well but I'm not sure), 1 isosynchronous enpoint IN for data from ADC, 1 isosynchronous enpoint OUT for data to DAC, and 2 others endpoint for the feedback
Thank you for this clear explanation ! I hope I dont look so stupid ^^
