PMillett Tube Preamp Build
Nice build Ricardus. I enjoyed reading through your documentation.  It is definitely a learning experience and using lundahl input transformers are a snare no expense but well worth it.    Have you done some more recording now?    What have you used it on so far.
I've used this on vox, acoustic and electric guitars, and bass so far. Sounds great.
I've even brought it to live sound gigs just for fun when I was working with a singer songwriter person who only needed 2 inputs (voice and guitar) and it sounds great there too.
This is the final design for the panel. I came to the color choice (gold) over time.
I've been working on building 12 of the SSL 9000, 500-series preamps (I've got 8 done) and I settled on gold panels with cool blue knobs. So I ended up settling on gold with blue as a color scheme for a lot of the things I'm building.
I'm putting the band back together.
Also, I decided to build another two channels of this using CAPI's T-Pad output attenuator to be able to drive the tubes hard if you wanted to, and gain down the signal. I also ordered two of those EIZZ 24 step precision attenuators to use on the gain instead of pots.
Should be fun,
Should be fun,
Did you ever do these modifications on the second pair? I’m almost finished mine haha just waiting on the plates to be cut out. Trying to figure out where I can wire in an indicator light off the board.lol
I have all of the stuff, and the PCB's are done. I just need to order the rack case to finish it up, but money is tight. The last 4 months have been hell.
I used a 120 volt indicator light and just powered it off the mains.
I tried that but interestingly enough, the light comes on the moment I plug in the power supply, no matter if the switch is on or off. I’m perplexed by it.
Curious about these EIZZ, what do you think of them ? Do they click / detent from steps to steps ?
As he ^ said, yes they do. The click isn't loud like on a Grayhill, but they are detented and click a little.
I also agree the build quality seems excellent. They should last a really long time.
Can't wait to finish my 2nd PMillett preamp up.
