Awesome! Thanks so much!!!
could you try and measure the core dimensions?
just measure over the brackets,cans,or frames, close enuff,
can you see what color the lams are?
do you have a signal generator and an ammeter and voltmeter?
inject 20 Hz into the primaries at a level close to what the transformer might see, probably 1 to 5 volts,
write down voltage and current for each xfmr,
here is the test set up
