gltech said:
It would be cool if somebody came up with an easy way for cars and trucks making mostly the same longer trips to hook together for the common part of the haul to get some of the advantages trains have. Well, if you didn't have to worry about the stranger in the lead unit driving you off a cliff.
A while back, we went over this very topic at our weekly" think tank" meetings. (translation: a bunch of people from all disciplines, solving the world's problems, and drinking beer. Mostly drinking beer.)
We came up with a hinged towbar on the front of a car, remotely controlled to swing down from vertical to horizontal out in front of the car. But instead of a hitch, an array of really strong magnets at the tip.
Sneak up behind some unsuspecting semi trailer going your way, extend the magnets, and close the distance until you latch onto something steel. Slip it into neutral, shut off the motor, and relax. (bad for automatic transmissions since the '50s, no rear pump for lubrication while being towed. Standard trannys are fine.)
Time to disengage, just hit the brakes hard and "brake" free of your tow. Yank yourself off, as it were.
Never built, but we had some sketches, and settled on hydraulic control of lifting the towbar snowplow style, as a snowplow setup has a valve position that allows it to freefloat to make up for road humps/bumps.
Gene
