For Sale Random digital & MIDI gear (Sony, Lexicon, Akai, Yamaha, Atari, Waldorf)
ravachol
Ireland
*** Sony MU-R201 digital reverb ***
Sounds great, looks great. Operationally, all seems fine: buttons/functions work as expected. However, there’s some occasional erratic behaviour with the meter and the LCD —not correlated to any system noise, just a loose cable connection or something…. and I’ll be dammed if I can figure out how to open the case to check.
100V version but I’ve no problems running at 110V-120V —the Bando power transformer has no complaints, noise floor unchanged, everything stable.
€110
A second unit is available; in top shape, sounds great, works great —mo issues. €190 (see photos below)
*** Lexicon PCM-60 ***
Passes audio but the effect signal has disappeared. Research so far concludes that it’s probably a power supply issue —something quite common with these units. It sounded great not so long ago.
€460
*** Akai MFC 42 ***
In excellent condition other than the fact that it won’t power up.
€380
*** Yamaha FX-500 ***
Fully operational; versatile and characterful, however, the input jack needs some attention, some intermittency there.
€110
(UK power supply +€15)
*** Korg 301dl ***
Compact and capable digital delay with a variety of tones; nice ducking feature. Two memory slots, switchable instrument/line input, 9V rated but happily takes 10V. Future classic.
€80
*** Atari Mega-STE motherboard ***
Build your MIDI brain. Loaded with TOS 2.06 (German) and 4MB RAM
€300
  • Hard disk controller with original hard disk (40mb) +€70
  • C-LAB Creator dongle +€70
  • Cubase dongle (clone) +€25
  • Emagic NSL3 (Unitor N) +130
  • Set of C-LAB Creator printed manuals (German) +€20
*** Waldorf 4-Pole Filter ***
9V version with the CEM filter. Operating system works fine; it’s passing audio but the filter itself is unstable. A recapping of the power section might do the trick.
€225
I also have another unit available; 12V Moog filter version in good working order. €435
Sony MU-R201
Yamaha FX-500 in good nick
miscellaneous Atari kit
Akai MFC-42 pics
Lexicon PCM-60
double-boxed and ready to move
2x Waldorf 4-Pole
