Hi All
Here's my next project - a tube preamp with a 'drive' section and EQ.
It's to go with the fairchild 660 style limiter I'm building - you can see it in my PMSix661 DIY thread.
It's based on the redd47 style of preamp feeding a pentode 'drive' section before an enhanced fender style EQ.
All that onto a push-pull line amp with a centre tap fed output transformer.
The transformers are a shielded utc ouncer for the mic in and a Haufe for the line in.
I'm arranging those to have seperate connectors and be relay switchable along with the preamp relay switchable HiZ input to grid. So the front panel has a rotary switch for +48V, Mic and Line inputs, over-ridden by the HiZ input.
The redd47 style preamp is Guavatone's (Charlie) really nice Orange 86. My fav mic/line preamp really.
It is feeding an Edcor 10K:600 output transformer in the usual parallel triode stage parallel feed way.
The secondary of that transformer then goes direct to an EQ network - a fender bass/mid/treble style affair with a few enhancements.
Like the usual 'bright' and 'deep' switches as well as a switchable 'shift' pot that moves the centre freqs of the high and low along some. And also a 'depth' and bypass switch. Basically some variation on that venerable old tone stack.
After the EQ, there will be a grounded cathode triode gain make up stage, feeding a high-gain pentode with some 'drive' control. That is passed onto some simple HPF, LPF switches for final band limiting as required.
All that then goes to a simple split load phase splitter and the finals + push pull output transformer, again an Edcor 10K:600.
They are to be cathode biased, hopefully to combine with the 1st stage 'squish' to make the whole thing somewhat 'compressy'.
PSU is the same transformer I've used lots of times : 250VAC non centre tapped secondary at 100mA giving around 315V B+.
I will use the Orange86 on board PI filter + HV regulator to give around 35mA at 275V or so of regulated for everything but the finals, and around 50mA of 250V or so unregulated for the finals. Around 85mA all up of HV I think.
Actually, the on board regulation is perfectly happy doing the full 85mA so I'll prolly just do that. I make sure I adjust the pi-filter to make the regulation dissippation as low as possible.
There is also a winding for 24VAC-0 at 1A for regulated utilities like lights, relays, JLM VU Buffer rail as well as 48V phantom.
I'm using a JLM 3-rail pcb here. The -ve rail is unused. The 'doubling' mode will do the phantom.
The JLM ac/dc is pretty versatile - you can use it with centre tap ac for bipolar dc or non ct and disable the -ve rail with a simple link.
The heater winding is 9VAC at 2.5A converted to unregulated DC for the required 2.4A of heater.
Using a big bridge rectifier and 25KuF of filtering here, along with a high power dropping resistor of around 0.5R 25W.
Tubes will be :
- Russian 6J32 (EF86 style) type pentode (tube 1) and 6N1P (6922 style) in the Orange 86 pre (tube 2)
- GE 6BZ7 (AV7 style) for the EQ makeup gain (tube 3a)
- Sylvania 6BC5 drive pentode stage (tube 4)
- GE 6BZ7 (AV7 style) split load phase splitter (tube 3b)
- GE 6S4A x2 (single strong triode) for the push pull finals (tubes 5,6)
Right then.
So you get the idea - a single channel 2RU chassis with hardware bypassing, a buffered VU meter in addition to an interesting and overly complicated set of features
somewhat reminiscent of a guit-amp 8)
Just my style!
This is a relatively cheap affair, around 600us or so I would say, with 150 of that in delivery for the parts.
After all, next stop southwards of me is Antarctica.
Here's a pic of the rolling chassis, main parts and the current state of front panel design.
I'll finalise the design and finish the front panel pretty quickly. Only 1 VU meter hole to file!
I'll be knocking this together in the short term, because I figure the limiter I will partner it with will be done soon.
And I'm thinking there is a nice place in my music room for this combo.
My last word in preamp+eq DIY and limiters, for that matter :'( but ;D too
Tubes will be :
Right then.
Just my style!
