G-Sun said:Gustav: I see the kit is removed from you shop.
Is it still coming, or has there been some change of plans?
I haven't looked through the BOM closely. Many hard-to-find items/ many vendors if buying just a pcb?
Ok, thanks for the info!Gustav said:G-Sun said:Gustav: I see the kit is removed from you shop.
Just one "hard-to-find" part - 4M7 dual gang pot, which can be found at Reichelt.
Alpha seems to have lost my original order for pots, so I have to wait another 3 months, which is why I took it down.
Gustav
Gustav said:Just one "hard-to-find" part - 4M7 dual gang pot, which can be found at Reichelt.
Gustav
Wayne said:cool so just powered up my build seems to be working
Anyone go any tips on how I calibrate the VU's on this?
Wayne
Greg S. said:Hi Guys,
finally I wanted to denoise my early built Sym Fet.
Greg S. said:Does someone know,
Are there some wrong printed parts?
1 At The Pre Amp e.g. are 3 30K for each Channel,
Gustav told me to use 30R, same at his built guide.
Greg S. said:2 Why are there 2200-4700uF at the Lundahls?
I mean, the 1176LN got there 470uF
The original didn't got one!
Greg S. said:I mean, never ever use a C direct into the Signalpath,
Greg S. said:3 Did some checked why there are Labeled 4 Ratios and at the Lorlins got 3 Connctions?
just.sounds said:I almost completed one of these puppys. Nice sound !! on one channel....
One problem one channel seems to POP the output cap (before the trafo) one output cap was making acousitical sound and another one started to leak fluid....
Any guess what could cause this? The input/gain reduction on this channel is looking fine. Opamp is fine output transistors are checked and replaced so there must be a short somewhere. but i can not find it yet.
mike76 said:Hi,
I was wondering how much current is necessary for the device? Would approx. 300mA be enough? How would I get to know how much is enough (from theory or calculating)?
Thanks guys and girls.
