mike76 said:Hi there,
I just build my second unit after totally killed the first after connecting the front PCB the wrong way. After trying to remove the angled connection, I damaged the PCB. So I ordered a second one, which I got ready to go.
It doesn't work as expected, one channel does not give any sound, although the meter is corresponding.
I have got 2 pcs of NPD5566, which I got from China. What would an appropriate replacement for that? I can't get no answer, beside the bf245 in this thread. I'm not really sure, if they are working.
I think, something in the output section seems not to work. May the output transformer is not giving the signal, cause I built adapter-pcb for edcor xs 1100. On the IC, the current seems to be fine, I'm not getting through the schematic where to look else or how to measure, if the transformer is working. Should I get an audoi signal at the outputs, when the transformers are removed?
Thanks, it is getting frustrating.
Gustav said:mike76 said:Also - did you check the build guide/notice one set of pads on the dual gang pots need to be jumped if you use those?
Might you please explain your Post Gustav?
Greg S. said:Gustav said:mike76 said:Also - did you check the build guide/notice one set of pads on the dual gang pots need to be jumped if you use those?
Greg, I think, Gustav means that the middle row of the pot pads has no function and doesn't have to be connected.
I did not do this, but I used wires with connectors, which I want to remove to See, if something is wrong here. Unfortunately, my soldering Station is not working anymore, the new one should arrive soon. Thanks for your suggestions, Gustav. I will try it soon.
Gustav said:I just did some work on the assembly guide, and Ill do a small calibration guide.
Gustav
Nick Franklin said:Fired mine up last night. All the voltages check out. Just waiting for my release pot to arrive then I'll calibrate and see how this sucker sounds
Gustav said:Nick Franklin said:Fired mine up last night. All the voltages check out. Just waiting for my release pot to arrive then I'll calibrate and see how this sucker sounds
You could set a fixed release to get you going
Hope it works out.
Gustav
Nick Franklin said:I'll post some pics when I'm done.
Gustav said:Also, I would run it on 15V (2 x 15V), based on the feedback from builders.
Gustav
