Studio Projects B3 with intermitent sound
camarada78
Rio de Janeiro - Brasil
Hello,
I have here in my bench a SP B3 (transformerless fet condenser) that appears to work for a few seconds than shuts down. A few moments later, it goes back working again and then it stops.
I thought it could be humidity on the capsule but after a few hours on the dehumidifier, it came back identical, the same problem. Any clues?
Any thought?
Thanks have a good day
Any thought?
I had the same problem with an SP B1.
The black rubber base under the capsule had deteriorated and contaminated the diaphragm.
AND one of those black switches seemed to have oxidised. Laying directly on the Hi Z path.
Check the state of that capsule, any tiny black deposits/contaminants?
For the switches, clean them wit DE-Oxit spray cleaner, see if it helps.
Good luck to you!
M
