TAB/ Telefunken V372 BSY90 Transistor replacement
Marceldarcel
Member
Germany
Hello folks,
recently, I recapped my V372 because some capacitors had leaked. Unfortunately, I soldered capacitors C6 and C7 in reverse, causing R14 to burn out.
I tested the BSY90 with a diode test and it seems to be faulty. I'm new to electronics and have no idea which transistor I can use to replace the BSY90 in this circuit. Do you have any tips?
Thanks in advance!
Best regards
  • V372 Data Sheet.pdf
