beezer4
Hi all,
I repaired a TAC Scorpion power supply for a friend. The fuse holders and cable had dried out and something eventually shorted inside. I replaced quite a few components and had it back up and running solid not under load in my shop. Once the power supply is connected to the board, the V+ rail drops out. I'm helping him troubleshoot remotely and we've determined the V+ drops after a certain amount of channel strips are added into the console. I'm guessing it's a power draw / amperage issue, but am wracking my brain on where to start. Anyone have any immediate suggestions? It's difficult as I cannot be in front the console. Schematic attached.
Context on what was replaced:
Replaced Q1 with TIP32AG: https://www.mouser.com/ProductDetail/863-TIP32AG
Replace Q2 with NTE 219 PNP Power Transistor: https://bit.ly/2G4FjhM
Replaced U1 and U2 with NTE 935 Positive Voltage Reg: https://bit.ly/2R604jp
Replaced U3 with NTE 970 Positive Voltage Reg: https://bit.ly/378XQp7
Replaced 3 fuse holders with connectors and all fuses
Replace R17 resistor
Replace 48v bridge rectifier
Replace C13
Replace C14
Replace any bad diodes
Replace C13
Replace C14
