Dorin Bodea
Active member
This stereo 23 steps transformer volume control is a 6th generation proprietary design. Its primary function is line level control volume but contains a high quality permalloy that you can use it also - inverting cables in the back and a short trial and error - as fixed step-up line level transformer or adaptable to DAC stages or MC step-up for moving coil cartridges! It is also small (actually the smallest I've seen), compact layout and nice looking
The basic version is a 1:1, 10k:10k, 80H@20Hz, but other transformer ratios can be made. Also balanced/unbalanced versions are possible. The logarithmic curve is according with IEC 60393-1 code 15A law. For this 1:1 version see the THD figures for 0.7Vrms at highest step (with the soundcard having about 0.0005% THD in loopback), also the frequency response 10-100kHz, these specs being of course in the same ballpark at any step.
It is neither bifilar winding nor autotransformer so therefore it has some additional isolation from various noises
Thanks, take care!
Thanks, take care!
