Triad, UTC, Stancor, Peerless, and others
WannaBee
I am divesting myself of these transformers which I intended to build commercially into color boxes. HS-56V, HS-54, UTC a21/22/20 and  600:600 and others.  As you can see I have a tremendous collection that needs to go to clear space.  Prices range from $100 up.
Ships from LA, local pickup possible. All tested and guaranteed working on arrival.
Many HS54's. One set 52s offered to first responder. No promise another set
Of 52s will be located.
This is the pair of 52's, not yet payed for.
These are some of the 54's, many to be had.
If anyone desires some build ideas please pm me. La2a, 1176 and even a mic pre are possible....
We are fairly certain we found a pair of 66's in the stash.  Biasrocks had asked first so I await his response. Next up will be Winetree if Biasrocks is out of bounds....
SC has first dibs on 52's and we are waiting another hour for his move.  Next up will be whomever assumes SC position upon default.
http://groupdiy.com/index.php?topic=47410.0
HS-54 can be used for low gain 1 bottle or V72 application.
ravachol said:
SC has moved to bed so somebody else can have the HS-52's instead.
Now I get it, this is SC.  Ok, 52's definitely still available....
ATTENTION:
56 is a 66 in a double shielded can. 56 is a better part, hermetically sealed, another HUGE plus.
We've only touched the tip of the iceberg.....
