Hey folks,
since I got hold of a set of original output and interstange transformers for these I'm planing on building a clone.
I got the original manual which has some valuable informations. Such as the "official" mod for variable attack.
There is a thread here on Groupdiy where PRR posted a mod. But it's not correct.
To get variable attack on these you have to vary R34 (220 Ohm). Higher value or no resistor at all means quicker attack lower value means slower attack. When the resistor is omitted the attack is 30us. But they warn that such fast attack will rise distortion at low and mid frequencies. They advise a range from 100us to 10ms.
The manual also states, that no matter if the limiter is on or not the output is limited to +6dBu.
Can anyone tell me, where this limiting takes place?
I simulated the circuit in Spice and got it kind of working. The limiting is also active in the simulation. Or at least I see sinewaves getting cut off when going over +16dBu...
I tried a few things but I can't find the source for the limiting. My electronic knowledge is just too non existent to understand what's going on in this circuit...
I disconnected the sidechain and the limit was still there. So I assume it's in the makeup amp?
I can upload my Spice simulation if that helps.
PS: Just for info, U273b and U373a are basically the same except the second output transformer in the U273b for different output levels.
And there is an error in the floating schematics. There is no connection between C16 and R16.
