U47 MICROPHONE BODY | LA-2A CHASSIS P2P | MECHANICS OF HIGH QUALITY
I looked at the pictures, and yes I can see, not a render, the body look amazing.
Will check, but I am probably in for 1 or 2.
DJN
Wow. The mic body looks great! Are the dimensions the same as the original one?
If so, I´d be up for one to two of these!
cheers
Hello,
I was wondering any clue on the lead time ?
Second, is the capsule holder included ? And is it possible to get a extra rail, so you can use three, when you want to build point to point ?
Kind regards Dirk Jan
Pip said:
Yes LA2A is nice but whats up with the mic body?
Hi Pip,
we are collecting pre-orders to produce the body microphone, as soon as we have the necessary quantity will be realized. is already possible to pre-order now, we'll make a small production for every 10 items ordered.
anjing said:
Hi Anthony can you give us more details? Like basket specs internal construction.
The photos look amazing!
Regards,
Pierre
HI,
we will make some more detailed photos in the week...
U47 BODY.
$540.00 CAD.
Must be for European's only!!
Just to be clear, is the headbasket included ? In your first post is says no, but on all the pictures it is there.
Otherwise the following parts are:
- bottom bell with or wihout binder insert.
- microfoon body tube
- support struts
- mic top holder
- headbasket ???
DJN
Its been a few weeks, is this body still happening?
If your one away from starting production i'll buy.
I think you should sell me your photographed body above.
:) j
ilfungo said:
Sorry I've build 2 LA2A with this wonderful case, The meter is Sifam AL39 WF no 29.....
Ciao!
Just a brief follow up on the Sifam AL39WF meter. I got it and it fits perfectly. For the meter light I took the 'Lightbox' illumination kit, seen for instance at Cayocosta's build, but it was too big for this case. Couldn't close the faceplate.
I will have this coming soon , just in case some folks would be interested,  it should fit this body perfectly as well looks like same footprints as equinox,
EF800  D-47 with AMI T47 and Classic BV08 from AMI support
it will have a reed relay for True Omni switching from the psu rocker switch.
just need to adapt the psu and test it ,
Dan,
