U47 with EF14 tube Build
I do not know, I just copied the textbook delon bridge circuit.:)
Rock, you did; Spence didn't.
https://en.wikipedia.org/wiki/Voltage_doubler#/media/File:Bridge_voltage_doubler.svg
That’s what I thought was strange as if I don’t gnd the voltage supply it doesn’t run any voltage?
The other option is to take the second gnd out is it?
I promise i don't mean to be mean, but... Are you completely sure you should be messing around with things like this, without a (more) comprehensive understanding of the basics? 😕
Sounds to me like there are some confusions and/or false assumptions messing with things somewhere...
https://sound-au.com/articles/index.htm#psud
In my defense it didn’t work when I did it correctly that’s why I put the other gnd on there and the sim worked.
And that is exactly why im simulating it before I do it for real
So the simulation didn't work if the negative end of V2 was not connected to ground?
Sidenote: in LTspice, the amplitude for the sine source is actually the PEAK amplitude, not the RMS value transformer ratings are in. So V2 is putting out 17Vpk, or 34Vpp.
Do you have a particular simulation model for those polarized electrolytic capacitor symbols there? I use the stock symbol you get when you press C on the keyboard, or click the capacitor symbol in the toolbar. I'm starting to wonder if those are actually working as the capacitors they're intended to be, within the simulation...
Just slapped together this quick sim, and works fine with the floating voltage source.
So the heater winding of your transformer is supposed to put out 6.3V AC? That would translate to an 8.8V amplitude for the LTspice sine source. And didn't the UK run on 50Hz mains?
Later edit: 2nd attached screenshot also contains an LM317 with some eyeballed adjustment resistors, putting out about 6.5V (blue trace; white trace is LM317 input voltage).
No idea what exactly is or isn't going on in your sim... Do you have 17V set also as a DC offset for V2? Labels are overlapping with the 1N4007 of D7...
well i dont know whats going on with my ltspice, as ive put in what you've done and when i check voltages i can see on the plot what the voltages are but when i place data label on there its just a 0v?
on my version of what you have done with the lm317 mine outputs 3v and not 6.5v like yours but all the components are the same?
ive installed the latest version and it does seem to be almost working, just the data label is incorrect now
when i plot i can see voltages are correct and are what they should be.
just dont know why data label isnt working?
What's in the simulation syntax? Could it be that it defaults to the ".startup" argument being on, and the labels show that initial 0V value?
Still some answers missing though...
yes uk on 50hz and yes to 8.8v amplitude on H+ 6.3 x 1.4 = 8.8
i had it set to 17v dv as the sine didnt seem to be working, as this mac version seems to have many problems which are not all my errors
That Mac version of LTspice does indeed seem to be all over the place, for reasons i can't even speculate on... 🤦‍♂️
If you add a DC offset to that, how do you expect that (AC-coupled) voltage doubler to do what it's supposed to do? No point in bothering simulating that voltage doubler arrangement at all, in the first place, then.
What "dc offset"?
And CAN you even display anything else than the results of the .op (DC quiescent operating point), in those labels?
