terry setter
- Joined
- Nov 17, 2013
- Messages
- 153
Three things:
1) Reducing C1 to a very small value will attenuate low frequencies below a cutoff point that is primarily determined by the interaction between C1 and the grid resistor. Single-pole, 6dB/Octave.
2) If you try to do the equivalent by lowering R3 as was suggested, there will be noise-related consequences (depending on how low you go those consequences will be kinda small or very small, but real). Some folks are sensitive to how the grid resistor value affects the overall sound of a mic, but that's much harder to pin down than changes in circuit noise. You can find a lot of info online about the "optimum" grid resistor value, but generally, you'll see that few folks go higher than 1 gig (yes, there are notable exceptions) because Shot noise gets significant when the grid resistor gets very, very large like that. And, as mentioned earlier in this thread, going below 60 Megs might possibly take you into non-Neumann sounding results. I don't know how low you'd have to take R3 to get the reduced bass you're seeking, but the Elam 251 used a 30 Megs (and were not known for being overly quiet - for a number of contributing reasons). Summary: making C1 smaller has got far less baggage associated with it than reducing R3.
3) Your measured frequency response is so rough that I'm wondering if those are acoustic response measurements, rather than plain old "mic amplifier circuit-olny measurements" made with a 50-70pF cap to replace the actual capsule and fed into, say 1500 Ohms. If your frequency response chart is of acoustic pickup in a room, then peaks and valleys in your room's bass response are what you've been seeing on your measurements. Even if you are using gated measurement techniques, your results in all but the largest enclosed spaces will be suspect below about 200HZ and get more and more unreliable as the frequency goes down. I would expect the electronics of your mic to be much, much flatter than the chart you've posted.
