Thanks for the info. I guess time and wear play a big role as to why they can sound different even if they’re from the same revision.You can pick 4 of each and probably hear differences between all of them.
yes those are #4 screws with 40 threads per inch.
There are 4 litle threaded pipes that get welded to the inside of the case, so the holes on the base are actually on the same piece of metal as the holes on the top.
If you want, you could just tap out the old threads with a slightly bigger metric tap, or just tie wrap the darn thing down with some heavy tie wraps.
