MatthewF
I've thought further on PRR's suggestion of using an inverting amplifier to generate bias voltage as a function of (variable) B+. To this end, I've sketched the attached schematic as a first attempt to visualise the circuit. Not shown is the power supply for the op amp (this should be around +15/-60v, derived from a separate mains transformer). The OPA445 datasheet: http://www.ti.com/lit/ds/symlink/opa445.pdf specs max supply voltage at +/-45v, and details a use case with +60/-12v supply, so hopefully this is reasonable.
R6 (1M pot) would be the front panel control for varying power amp voltages. Trimmer R2 is for bias trim, used when changing output tubes etc. The 9v zener at the input to IC1 is there to protect against over voltage at the op amp input. Resistor values are nominal and could of course be changed per application.
Aside from missing PSU decoupling caps at the op amp supply pins, can anyone spot anythig questionable in the drawing?
