Cqwet Dbdfte
- Joined
- Oct 2, 2023
- Messages
- 404
The phono pre-amps, with open inputs, have 3mV rms output noise and have 49.5dB gain at 1KHz, so ~69.5dB gain at 20Hz, to include passive RIAA network. If the pre-amps did not generate any noise, 1uV would the produce 3mV rms out, hence the susceptibility at the cartridge level.
On the turntable with 60Hz motor running, needle up, and 27dB transformers in line, I'm getting ~1.8mV and ~2.8mV of random noise, mostly low freq.
With this gain, the phono signal needs to be attenuated before hitting the power amps, with 15.5dB (voltage) gain.
At 20Hz the system would have (27+69.5+15.5 dB) 112dB gain, so attenuation is needed, which will also attenuate the noise.
I do not have a vinyl test disc ATM, so I cannot relate the noise to a cartridge signal level, other than noise in the speakers, where it s small enough not to be heard in a silent room, at "high" volume setting, unless I put my ear into the speaker element, not exactly scientific, but I'll get there.
The source of the 4dB extra noise in one channel I have to dig into, I suspect a noisier voltage ref in one of four current sources.
