AusTex64
- Joined
- Jun 3, 2013
- Messages
- 526
Some of you may remember a high frequency ringing problem at around 26KHz I ran into (it was actually GDIY member Sasarist that pointed it out to me) on my Drip V2 EQP-1A builds. The problem was most noticeable when boosting at full at 10K, 12K & 16K, bandwith at narrow. I used the older version Vintage Windings EQ-1A inductor, along with the suggested Sowter transformers. I discovered a few things along the way - most significant was that the inductor rings the worst when loaded with a low impedance. Evidently the original Triad HS29 with it's 20K source impedance was a good choice. I ended up using a UTC A-18 with a 15K source impedance, then tuned the interstage Zobel to suit. But I still was having problems with ringing on the Vintage Windings inductor, but was able to make the Carnhill behave in my build. So that's what I went with, and somewhat loudly endorsed.
I was corresponding with Chris Preston at Vintage Windings while this was going on. A few weeks later, he sent me another EQ-1A inductor to test. And I didn't have to ask - Chris is a stand up guy. It took me several months to get around to testing it (sorry Chris), but finally installed it in one of my EQP-1A builds last night and tested it with my QA401. Great news - the HF ring is gone! It's also really cool that Chris has discovered the discrepancies in the "accepted" EQP-1A cap and and inductor values and corrected his current EQ-1A inductors to get the frequency centers closer to the published specs.
I can now endorse the Vintage Windings EQ-1A inductor without reservation. Happy building!
