Electrobumps
The Power TX is centre tapped. A while ago I tried a humdinger and removed the centre tap for an artificial centre tap/Humdinger and the hum was really loud, maybe worth investigating again.A few pertinent points could be:
If the amp has simple heater grounding, for example if the heater mid-point was grounded through a heater winding CT, or externally with a humdinger, then for starters retrofit a humdinger pot and see how significant that pot can lower any observable hum. That addresses one of the main hum ingress paths - stray capacitance coupling to input stage grids.
Heater elevation addresses a different hum ingress path - that goes via the heater stray resistance to cathode. That path is very dependent on the tube being used - so imho it is worthwhile firstly swapping in/out different tubes to observe any noticeable change. The 'elevation' aims to use a difference in voltage between the heater and cathode to increase the stray resistance value, and hence suppress that hum leakage path. As the decoupling capacitor is the part passing the hum current, the capacitor should connect to the quiet 0V point of the input stage, rather than say a noisier chassis or power supply 0V point.
More detail on this in the linked article: https://dalmura.com.au/static/Hum article.pdf
As for the tubes I have noticed some pre amp tubes are good and others are moderate and a couple are terrible. While some hum is being injected at some point in the preamp stages I also have hum that is post pre amp.
