What would be a good project to use some old parts JAN 2N2920 LH0002CH
ubxf
los angeles
I just found a handful of those transistors and I was wondering if there was any audio applications they could be used in.
  • 2N2920.pdf
  • Texas Instruments | LH0002CH - Datasheet PDF & Tech Specs.pdf
the LH0002CH with a good opamp can make a great buffered opamp
The 2N2920 would work as the input pair in a discrete op-amp, although the noise figure doesn't look brilliant.
It has a relatively high collector-emitter voltage of 60V so would also work as the input pair in a power amplifier.
As @Gus mentioned you could use the LH0002 to buffer an op-amp output. The specs are right for a high-output headphone amplifier. With a good modern op-amp this could be very high performance.
