Which OEMs Actually Use The OPA627 / Other Uber-High Slew Rate OAs?
Monte McGuire said:
...it's much more annoying with SO packages, and downright unfeasible with more modern SMT packages.
Infeasible is a strong word...
My first prototype for my BS.Eng. thesis was a dead bug job with an MSOP8 and four six pin SOT-23. It held together long enough to prove the concept, but yes it was a pain to wire up. Strong magnification is required. Also a real SMT soldering tip.
ej_whyte said:
Great thread everyone, thanks
thermionic said:
Hi Micheal,
The oscillation was seen by connecting a probe to the o/p socket, with the i/p socket shorted. My audio analyser picked up broadband fuzz at around -50-ish. I then hooked the scope probe and saw 18mV of something sine-shaped at 18Mhz.
The layout is on stripboard! The next stage is to give it to the PCB designer I work with. It seems daft to prototype anything with a 'relatively' quick opamp such as the 4562 on strip-board, but you have to get proof of concept somewhere, right? With anything faster I suspect you'd have to go for a multi-layer PCB from the start. Just the inductance of an IC socket can set off some OAs.
edit - trust me, you don't need to see the layouts. The moral of the story is that just a couple of mm here and there can trigger bad behaviour if the OA is quite fast.
This is exactly the problem I am having right now. Trying to prototype on a solderless breadboard with LME49990 and OPA1612 is a time consuming process!
I recall trying to breadboard a simple digital circuit using a solder less breadboard back in the '80s and the capacitance between adjacent pins altered my circuit enough to make it unusable.  Back in the day I laid out some standard footprint PCB to build prototypes that reflected reality a little better.
Now with SMD I find I almost have to go straight to a PCB design because the tiny SMD parts with heat sink pads on the bottom are too hard for me to deal with point to point.
That's why you want SurfBoards. Stick them to a piece of copper-clad board and you have an instant ground plane, too.
-a
