Well here it is. ML12 PSU Gerbers. This is intended for open source project. Not for commercial use.
5-5-24 Updated BOM and silkscreen on Gerbers to reflect alternate U4. TL783 high voltage regulator adjustable output range of 1.25v to 125v. This part is better suited to supply 48 phantom volts compared to the standard LM317 which only is adjustable from 1.2v to 37v. If using TL783 *Omit* D8* & C21*.
