XLR inlet for mic bodies ala tbone , behringer etc
nashkato
Europe/Austria
hi
i´m looking for those XLR inlets on mics .
mostly on those cheapo mics the body is held by screwing the body pieces onto a thread on the XLR Plug .
anybody an idea where to get these , or what i´m talking about at all ?
david
Do you mean that green thing?
iirc. for some mic I screwed one out from switchcraft/cannon xlr connector.
in some brands(switchcraft or cannon) panel connector you could screw them out.
but dont know if you could buy them separately.
Sitchcraft A3M
http://media.digikey.com/photos/Switchcraft%20Photos/A3M.jpg
All the chinese versions (i use these 5-pin and 7-pin connectors in microphones)
https://files.cablewholesale.com/hires/10xr-012xx_04.jpg
Anotcher cheap type
http://www.soundfirst.com/XLR/XLR-3-12C.jpg
Neutrik NC3MC fits great (also with gold contacts) but these are hard to find
http://www.kovacselektronika.hu/sites/default/files/imagecache/product_full/products/kep_10584.jpg
could always just have a flat bottom and put in an neutrik/switchcraft panel mount.
Observe
http://www.sweetwater.com/images/closeup/750-RefMic_detail7.jpg
usually i´d do this , but as mentionend before , the XLR has got a thread on the outside to fix the main body part with the threaded bottom part
and this one got a few broken pins .
i will checkout the switchcraft option and see if they might fit , thanks
RuudNL said:
This one?
http://eu.mouser.com/ProductDetail/Switchcraft/QG3M/?qs=gNS5EA6ck2ZPGZCRNxpA7Q%3d%3d
Exactly!
These one are really great for replacing different non standard microphone connectors and good for replacement of klein tuchel in some sdc if fit.
http://eu.mouser.com/ProductDetail/Switchcraft/AAA3MZH/?qs=sGAEpiMZZMv0W4pxf2HiV%2fKFPKdMBYQJqM2N7YKWIZhkryAPMt%2fiVQ%3d%3d
Chinese version, which is cheaper will fit same way as switchcraft
Reviving this old thread, i run into it as i am in the same situation as nashkato. None info on net about this particular piece, was searching about this this week and found same results as you guys, the only forum on web talking about this, in this moment, GDIY did it again!  8)
So, i want also some 3 pin male XLR inserts , as bought these ultracheap cinese BM700/800 and used them only as body donor-headbasket- don't want to use their XLR inserts though, as soldering/wiring situation is like "gollum" :p and  dont want to get myself in a situation of desoldering and reuse a thing that is already a mess, especially into XLR pins that are my mic's "last station", if we could say. Think that the plastic part is almost melt from heat of soldering and you can easily bend the pins  ;D
My searching results had ended up with the same as you, plus that i found as an alternative that Shure (58,57 etc.) XLR replacement connector has aslo a screw but you need to cut this metal thing a bit as its big enough
https://www.thomann.de/gb/shure_xlr_buchse_fuer_sm58.htm, and the same will be needed to the Cannon that you mentioned guys above . I also found a kind of a nice datasheet/flyer from Ningbo with all sort of pins, but as expected, is only for large orders and factory use. Until time we do an XLR Insert Connector Groupbuy  :p :p
https://m.made-in-china.com/product/XLR-Connector-Parts-3pin-7pin-Inside-Part-with-Screw-728240552.html
To conclude, in a Switchcraft VS Cannon "fight" there could be any differences in quality or smthng between the two of them, as Switchcraft(with Neutrik of course) concidered to be always a more trusty option than Cannon as we speak about XLR connections...
What would you guys choose between two of them? Or there are not any differences at all in this particular piece?
PS. Want to finish my built and in my town can only find Cannons. I can have Switchcraft in a week by now and about Neutrik 3MC i have to order from other country so :p. Its okay to go with the Cannons?
Peace guys.
