So I think that Ohm's law just bit me in the butt. I just racked up 2 channels of yamaha M1516 input channels. The schematic for this can be found on Adam Holt's page herehttp://www.adamholtmusic.com/diy/M1516/M1516ChannelStrip.pdf. It's on page 14 if you should want to look. I've done some modifications so that I can pull the output after the buffer amp after the fader (which I've replaced with a TL072), among some other mods that I do not believe contribute to this problem.
I am powering both modules with the kit from fivefishstudios http://fivefishstudios.com/index.php?option=com_content&task=view&id=43&Itemid=62 with a 30 VA transformer also from fivefishstudios.
Here is my problem:
When running frequency response sweeps I found a HPF around 125 Hz. It seems like there is a lack of power to drive the low frequencies, like if one leg of the xlr is disconnected. (I've checked the "balance" with a minilyzer, and it is normal.) So upon suggestion from a co-worker, I disconnected one channel and ran sweeps (just like how I tested while building) and the sweep is normal. I measured the current draw on the power rails and I am getting around 31 mA with one channel connected.
So my questions are as follows:
1) is my power supply sufficient for my project?
2) could this problem stem from excessive current draw from the addition of LEDs?
3) is there an easy fix such as swapping the power transformer for 50VA or so? or does the entire power supply have to be changed?
4) (a very basic question) if one channelstrip draws 31 mA, do 2 channelstrips draw 62 mA? Since I don't know AC analysis with opamps and transistors, how much current does this channelstrip draw?
Any answers to any of my questions would be extremely appreciated.
Thank you!
Here is my problem:
Thank you!
