Hey all, I have slowly been designing a solidstate preamp for over a year now in my spare time (not that much spare time..). I'm finally done, but there are a few nagging issues I have that I was wondering if folks could provide some help with. The basics: it is a dual JFET input class A preamp w/ 32V a bipolar supply. The output stage is a beefy MOSFET stage that has enough standing current to drive less than a couple hundred ohms at full output. The headroom is about 31dBu. I can get about 60dB of gain out of it. I have a working DC servo circuit, but have pretty low DC offset normally (of course it drifts a little). Also I use a Jensen output transformer for the balanced output. This was my first DIY pro audio project (even though I am an electrical engineer by profession) and I made assumptions in the beginning to make the design easier for me. So enough babbling, on to the issues. I will post a schematic at some point probably. (sorry for the long post, but i think i might raise some good topics here i split my issues up to different volumes)
1. Layout. I first breadboarded the circuit. I noticed while testing the unit with an AP analyzer, that referencing the breadboard to a ground plane reduced the noise by over 6dB. This was simply taking a piece of aluminium foil, placing it under a piece of paper which was under the board, and clipping the foil to star ground. I knew that there would be better electrical shielding once the board was in a metal enclosure, but I wanted to experiment with a ground plane on the board. I designed a layout and got a board fabricated with a ground plane. My plan was to compare the noise performance with a board with the ground plane to a board with the ground plane connections drilled out and individually wired back to a star point. I found that maybe the best solution is to individually route back ground connections to a star point, and have a ground plane connected only to star ground so that no part of the circuit uses the plane as a return path. I noticed many pro audio circuit boards have no plane at all. I have also read that some people do not use planes due to stray capacitances it can induce. The main thing I discovered is to definitely route back bypass capacitor ground returns to star seperately from everything else. Also a bigger cap here is not neccessarily better, as the charging current can cause hum in the rest of the circuitry. Thoughts on this? Anyone have anything to add? Also, what about audio transformer shielding, I haven't even looked into this at all? My noise performance is not bad. I think it was -120dBu referred to the input. The 60/120hz contribution was negligible. Of course I would like to improve the performance if possible. The majority of the noise came from the shunt feedback resistance. This leads me on to Volume 2: Gain Control. I'll post another topic soon.
