studer 089 schematic
EEMO1
Finland
might be a long shot, but could someone help me get a schematic for studer 089 console?
a friend of mine has one and he asked if it's possible to rack up one or two of the preamp channels...
thanks,
eero
https://www.reeltoreel.nl/studer/Public/Products/Mixing_Analog/189/Manuals/189_Op_Serv.pdf
Except for few pages concerning bloc diagram, which is just lager due to more modules but same routing, as frame drawing, it's identical for the diagram/schemo part of the pdf
Sadly I’ve seen this already. It doesn’t have a schematic for the signalisation board, which is toasted on mine and causing the cue buttons to behave unusually. I was hoping for a schematic of this board but it’s different from the mkii consoles.
Ok ! you have a MKI ?
I don't see that your link pointed to MKI wondering why the doc of MKII disappear...that's why I point the the 189MKII
AFAIK there is no dedicated MKI service manual available, but the MKII doc include most MKI modules already.
What is the ref of your card ?
The logic behind the CUE/PFL is not that complicated, should be easy to troubleshoot
Have a look at 1.090.060 schemo with the holding circuit at the bottom...MKI is probably not that far from this one.
Zam
Zam
Hey thanks so much, I think this is the exact schematic I was looking for!
Zam
Update...
I believe half of the circuit is basically identical to the schematic you mentioned, but there are other parts of the signalisation board that differ. I find it is somewhat similar to 7.090.065 in the manual. Any tips here? if someone has a good (unburnt) 080 MKI I'd love a picture of this board so I can copy the values down.
