ToroRojo
JB Weld For Mounting Brackets
« on: November 21, 2005, 04:48:25 PM »
I've been trying to figure out a way to mount the uberjam 1176 switch banks as well as the 1176 pcb to the par-metal chassis without having an ugly bolt head/nut sticking up on the outside of the chassis.
My tentative solution is to use some JB Weld and some U-Brackets.  Any thought for or against?   It seems like it would be sound (rofl).
PRR
« Reply #1 on: November 23, 2005, 12:25:34 AM »
JB may work; if the metal is really clean, if it does not go on tour with the HedBangers.
Do the switches have mounting bushings? That would be the simple solution.
ToroRojo
« Reply #2 on: November 23, 2005, 01:00:00 PM »
Weird.  I tried to post this a couple of days ago, but it gave me a database error, so I gave up and it magically appeared today.
I went ahead and used the jb weld.  It should be dry by tonight.  I'll mount the switch banks and report back.
The switch banks do not have mounting bushings.  I want to try and mount these guys without drilling holes in the front panel.  It looks cooler that way.     :thumb:
ToroRojo
« Reply #3 on: November 28, 2005, 02:10:58 AM »
I finished my G1176 today.  Here's a (sucky)picture of the JB Weld mount.  Basically, I cleaned the metal, JB Welded a nut to the front panel and used bolts and spacers to mount the switch bank.  It seems sturdy and is working great!  I guess only time will tell...
« Reply #4 on: November 28, 2005, 06:36:43 AM »
Nice One!  JB weld is great.  I made a valve spring compressor to remove the valves from my KZ550.  Oops wrong forum....
Last post January 27, 2006, 12:31:59 PM
by Hairball Audio
Last post January 02, 2012, 01:16:56 PM
by VacuumVoodoo
Last post June 17, 2019, 04:02:32 PM
by ruffrecords
Last post December 03, 2019, 10:57:23 AM
by weiss
