[quote author="rascalseven"]Hi, Brad,
I'm assuming you are talking about the api 2503 (Profile 4804) output transformer. Unfortunately, "brown wire" doesn't tell me enough. I don't know if you mean the positive or negative of the primary (brown is both, depending on which api schematic you look at). For clarification sake let's just assume that brown will be the positive lead of the primary:[/quote]
si, brown wire in the 312 schematic, which shows red and brown, in the 312 signal hot to red signal ground to brown, so I'll just switcheroo what you said below. The rest of your wiring scheme is as the 1:2 output on the 312, could probably use the left over winding as 1:1 for three (count them, three) outputs.
Brown wire to B283 pin F (or 1290 module output pin P)
Red wire to 'B-' (audio ground) which is pin E on the 1290 module output
Connect Yellow and Green wires together
Orange wire to XLR pin 2 (positive)
Blue wire to XLR pin 3 (negative)
XLR pin 1 to chassis
Note that this wires the 2503 in a 1:2 ratio, which gives about 6dB passive gain compared to the LO1166's 4dB, so it'll be a touch louder.
For the switchable output I mentioned above, use a DPDT toggle switch (on-on), connecting XLR pins 2 and 3 to the two poles of the switch. Then wire the positive leads from the LO1166 (pin 5) and 2503 (orange wire) to the positions for pin 2 and the negative leads of each (pin 8 on LO1166 and blue wire on 2503) to the positions for pin 3. This will give you a choice of output transformer at the flick of the switch.
One from scratch could have four pushbuttons, like the four at the bottom of Tommytones 1081 w/the fourth one on/on: eq, phase, phantom, and API, ha!
And no, you don't have to terminate the outputs from the LO1166 or the 2503. Just so long as the primaries of the LO1166 are always connected to B283 pins M and B, you'll be in good shape.
And don't forget to change C7 to 220uF.
Peace,
JC
Right, and don't forget to change out the phase switch so you can switch phase on both outputs with the same switch. Okay, so not knowing toooo much about API either, is this the transformer that's been described as "not much" as far as transformers go? Iron core, four windings, 75ohm each, originally a crappy $8 piece? Not to say it doesn't sound good, but it was a cheapo. I think this is the one. Any 1:1 or 1:2 with the right impedance should do fine, I'd think.
Unbalanced, what's the impedance of pin F? <10K? <1000? <100?
Here's Tim Ryan's schematics of the various doo-dads discussed for folks who can't find them--
SCA A12:
http://www.barryrudolph.com/greg/seventhcircle/a12/a12pdfs/io.pdf
N72:
http://www.barryrudolph.com/greg/seventhcircle/n72/n72pdfs/io.pdf
BA283:
http://www.barryrudolph.com/greg/seventhcircle/n72/n72pdfs/ba283-1.pdf
BA283 again:
http://www.barryrudolph.com/greg/seventhcircle/n72/n72pdfs/ba283-2.pdf[/quote]
