AudioJunkie
So my first time to deal with heatsinks.
If I use the T0-220 mounting kit with the insulator, do I still need the thermal grease?
Is thermal grease conductive? On the G9 everyone talkes about the 78s12 needing to be electrically isolated from the chassis if you heatsink it to the case.
I was just going to use an aluminium right angle to mount the G9 regulator so the bottom of the chassis. Should I use thermal grease on the bottom of the angle to better disperse the heat to the chassis?
Daniel
Daniel
