Advertised on eBay and AliExpress with such names "High voltage + filament Regulated power supply board for Tube preamp DIY L12-41," I opted to purchase one to power my "Mystery RCA mixer-amp" rebuild project, covered in another thread here.
PCB available, too: ![Maida-HV-circuit-board-top.png Maida-HV-circuit-board-top.png](https://cdn.imagearchive.com/groupdiy/data/attachments/70/70672-b0b3c8febf0b3ab33b11a5e244d6a2a2.jpg)
The various vendors who sell the board don't offer much in the way of documentation and what is supplied can be a little hard to understand.
So far, I'm happy enough with the board, it does what it says it does. But, lacking a schematic I was feeling a little lost. With some time on my hands I did some digging and would like to share some information about it. What I like about the board is they included ventilation holes throughout the board for the heatsinks and higher wattage resistors. The I/O screw connectors and PCB are of good quality.
Cutting to the chase, I drew a schematic that's pretty darn close to what's on the board:
![Scheme-it-export-Maida-HV-Fliament-Regulator-Board-2023-12-16-09-13.png Scheme-it-export-Maida-HV-Fliament-Regulator-Board-2023-12-16-09-13.png](https://cdn.imagearchive.com/groupdiy/data/attachments/70/70670-8351149a9d13cec5036c36f24ef321bd.jpg)
Drawing is done in DigiKey's Scheme-It; it needs a little refining and a double-check of the exact values on the board.
I came across a more original version of the H.V. section in this post:
https://www.diyaudio.com/community/threads/tip50-lm317-high-voltage-regulator.61831/#post-2050076
The L.V. section schematic comes from a similar product for powering filaments only.
![LV-PowerSupply.jpg LV-PowerSupply.jpg](https://cdn.imagearchive.com/groupdiy/data/attachments/70/70675-9c9d1804cced014f799713adcdc5d25f.jpg)
After reading up on Maida H.V. regulation I felt like there were a few things lacking in this board. The first being not much in the way of capacitor bypassing around the LM317s; the second is the large value capacitors on the outputs.
I've installed input/output bypassing with 100nF caps to hopefully suppress noise.
I pulled the 100uF/400V cap on the board's H.V. output and using (for the moment) a 15uF/300V electrolytic in its place. On the L.V. section I'm using a 220uF/25V cap instead of the 1000uF supplied with with the board.
To build it out into a usable supply I decided to use an old Eico MX-99 Multiplex Adapter I've had for a long time and didn't think I'd ever use as a donor chassis for the project.
![Maida-HV-LV-PowerSupply.jpg Maida-HV-LV-PowerSupply.jpg](https://cdn.imagearchive.com/groupdiy/data/attachments/70/70678-f498ce91208ff03ae05db7841f9a4c61.jpg)
On the bottom side of the chassis I have two Triad toroidal transformers mounted. The HV regulator is set to provide 250V and the LV set for 6.3V.
Cheers!
![HV-circuit-board.jpg HV-circuit-board.jpg](https://cdn.imagearchive.com/groupdiy/data/attachments/70/70674-7bd91b6a8c7572490061771b7b7d5074.jpg)
![EicoMX99.jpg EicoMX99.jpg](https://cdn.imagearchive.com/groupdiy/data/attachments/70/70677-6b0069a5368a439c0fe4604b88d7120c.jpg)
Cheers!
