electrorocket
Member
I've got a TCM1150 I did a bunch of the standard mods too, and finally got working. But now the level is only sufficient in any position other than true omni. Even then it's quite low. I close miced a 12 string in figure 8, and the gain on the Octane was cranked. I never got over -12 db on the pro tools track. I put it in omni, and the level gradually decreases significantly over about 5 seconds. There's only one capsule being used in omni, correct? But I thought if one of the capsules wasn't wired, there wouldn't be that gradual drop, and there would be no signal at all. Can someone help me out on this? Where should I look? Thanks!
