amplexus
My bad- the 2291ungapped. I have a couple builds on the go- one uses the 2290. Tho it should still work fine with either I believe.gapped push-pull opt?
No idea- it'll depend on what I land on for PCB features, and how much interest there is- ie: how many boards I'll order from fab etc.. This got seriously backburnered this year because of a bunch of big projects/contracts that happened. But I think I can put it back on the todo list!Curious how much this kit costs all in with PSU? Is there a build guide that comes with it? Looks really fun.
OP used Cinemag Quad Eight 37,5-150-600:50k (with secondary center tap) input having ratio of at 1:9 wired as 600:50k, 1:18 wired as 150:50k, etc. This is probably close to ratios used in original, typical 1:7 or 1:10 came later. 4:1 push pull output was also common for this type of circuit. I don't have data for originals to say for sure what they were, Amplexus and EMRR should know more.Is there any info on the input and output transformers turns ratio?
I'd guess something like 1:7 on the input and 4:1 on the output? Anybody?
Could integrate that on a single stepped 2p switch with enough positions, right? Like second stage at minimum until click 6 and then 1st stage stays strapped at max gain and the second stage carries on through the switch travel…As it is now, the gain of the circuit is rather high even in the minimum setting. I'm wondering if it's reasonable to do the gain adjustment at the first stage as well. For example, set minimum gain at the second stage and arrange the same circuit for gain adjustment for the first stage as it is arranged at the second stage (cathode resistance change). When gain is maxed at the first stage, the second stage gain adjustment comes into play.
Any thoughts/objections?
The reason for having the I/Pt off-board was mostly cus I wasn’t sure which of the two or three transformers I wasOP used Cinemag Quad Eight 37,5-150-600:50k input having ratio of at 1:9 wired as 600:50k, 1:18 wired as 150:50k, etc. This is probably close to ratios used in original, typical 1:7 or 1:10 came later. 4:1 push pull output was also common for this type of output. I don't have data for originals to say for sure what they were, Amplexus and EMRR should know more.
Input's secondary has very long wire possibly picking interference, high end is probably fine without shield. I like it having no more than a few cm long sec. signal wire (shortest possible) and use relays for switching DI input, or changing load. Searching the forum finds nothing, i might still have lengthy mail from Cinemag about this matter.
Small details like this are important when working with tiny mic signals.
Exactly! That’s what I thought of doing. You described it in a much more elegant way than I did)Could integrate that on a single stepped 2p switch with enough positions, right? Like second stage at minimum until click 6 and then 1st stage stays strapped at max gain and the second stage carries on through the switch travel…
Is that kinda what you’re thinkin?
I Could run the numbers- but it’s easy enough to knock into the prototype board i’ve already got built! Things are slow in the next couple weeks so I can maybe put this on the front burner again.Exactly! That’s what I thought of doing. You described it in a much more elegant way than I did)
I was thinking about noise due to increased cathode resistance, but I need to refresh my knowledge about tube circuits and noise contribution of various components.
