chrissugar
I need for a special experiment a very low distortion line level output buffer, powered from differential PSU for DC coupling (+/-15 or 24V). Something in the direction of the Jung buffer.
Unfortunately this is not the only requirement. It should have an output impedance under 1ohm.
The obvious thing that comes to my mind is to do something in the direction of a power amp.
Question is, how would you do that? What would be the best compromise to achieve this? (using power output devices, paralleling output devices, playing with negative feedback, etc)
This low out Z requirement also would exclude any 50ohm resistor added at the output of the buffer to isolate cable capacitance and RFI from the outside. Probably something like the parallel RL network used in the Hardy preamp would solve this (0ohm in audio band, 39ohm at high freq)
I know, too many questions. :grin:
Would be happy to hear you thoughts about this subject.
chrissugar
chrissugar
