Hi everyone !
As I've got a little bit of time by now, I'm planning to build my own tube preamp for my B*rhinger B2 (not the Pro one).
Here are the things I found interesting to use:
- no input and output tranformer to avoid bandwith problem.
- 48V phantom power
- based on one 12AX7 (one should be enough in my opinion)
A few things should be cleared anyway:
- how can I make a balanced stage with tubes ? WITHOUT tranformer, don't forget, it's one my goal.
- I need high voltage gain to get nearly +4dBu output. But I also need low output impedance on my preamp. I plan to use a common cathode stage (for high gain), followed by a cathode follower to lower the output impedance...
- Between those 2 previous stages, I could implement a dephaser to recover balanced output. But it would add an other tube.
I'm interested in all your ideas !
Thanks to all of you in advance !
- 48V phantom power
