Part of that is probably the 6V filament supply maybe?
To be honest i have no real idea if these last tests were made with or without the tube installed.
Sorry, I didn't mention it since I thought it had to be installed. All the tests were done with the tube installed. Should I repeat them without it?To be honest i have no real idea if these last tests were made with or without the tube installed.
This does NOT happen when in bypass. In bypass it's dead silent.
When the tube stages are bypassed, or the cabsim, or both?
Well, even that first triode has "quite some" gain to begin with.
https://www.ampbooks.com/mobile/amplifier-calculators/output-impedance/calculator/
100k plate resistor and 1.5k cathode resistor (bypassed) has a gain of (up to) 61x or so / 35dB. That'll be amplifying everything (including hum) by a relative lot.
Is this going into an instrument input, or a line input, on your Ultralite? Is the power supply of that earthed (3-pin mains) or not? And does that connect to a laptop, or a desktop?
Maybe I should look for a way to tame that output a bit?
It's going into the jack input of IN1 on the Ultralite. Being a combo input I think it works as an instrument input when using jack connector.
The ultralite is connected only through usb to my macbook on battery (PSU not connected)
Exactly. When's the last time you've seen or heard of a balanced instrument input? And especially if you're using the balanced-out, why would you NOT want to go into a line input?
Ultralite can't be USB-bus-powered, so i assume that's powered with its own not-earthed PSU? And do you still get hum without touching the enclosure, if you connect the macbook's psu?
I assumed that the combo inputs on the Ultralite are mic input if using the XLR connector and line input if using the jack connector.
Ultralite can be USB powered, at least my old firewire one can (it's the mk3).
If I connect the Macbook PSU nothing seems to change. I've noticed that if I touch the macbook hum disappears.
I think probably it's a gain/impedance thing and that the noise floor raises and lets us listen to the hiss and hum
Sure, that's why it (ONLY) says "Mic/Instr" right under it, right?![]()
Sorry, I meant FW. Well I meant that I'm not using any PSU. It's only connected to the laptop.It can be powered via Firewire, but not via USB.
Well, that doesn't help much then - i guess the last few generations only had two-pin (double-insulated) power supplies![]()
Well, sadly, in the real world it's difficult (or rather impossible) to ONLY amplify the intended signal, but not the noise...
Sorry, I still don't follow you. What am I doing wrong?
I don't know if it's a language barrier or something else, but I'm sorry, again I don't follow you. I don't understand what you mean.
Do you mean that I'll have to live with that? That's just the way it is?
As you can read under the XLR-combo connectors, those are for mics and instrument inputs. That could work, if you connect the "direct out" unbalanced into one of those. The "DI out" you'll want to connect to one of the line inputs on the back.
I see what you mean now. Thanks for the linkshttps://en.wikipedia.org/wiki/Appliance_classes#Class_II (double insulated)
versus
https://en.wikipedia.org/wiki/Appliance_classes#Class_I (earthed)
When you touch the metal enclosure, you're conducting the leakage current (which causes the hum) to earth, that's why it goes quiet. The laptop's power supply not being earthed doesn't help.
I wonder if the hum still presents, if you hooked up the Ultralite to a desktop or another laptop with an earthed power brick.
https://robrobinette.com/How_The_TMB_Tone_Stack_Works.htmOne little question: to my taste, the Bass pot doesn't really add much bass when turning it to the right. It subtracts bass when turning it to the left though. How could I make it work so that it adds more bass when cranking it up? Is it the pot value (B25K), C8 (47nF), or none of those?
[I assumed that the combo inputs on the Ultralite are mic input if using the XLR connector and line input if using the jack connector] -- The NEUTRIK "Combo" connectors are designed to accept "balanced" (or, "stereo") signals from either an XLR-style connector or a 1/4-inch (6.35mm) TRS-style connector.I assumed that the combo inputs on the Ultralite are mic input if using the XLR connector and line input if using the jack connector.
