Guitar pickup winding?
Nadege
Belgium
Hello,
I would like to begin some experimentation in guitar pickup winding, as I owned an old electric guitar with broken microphones...
Does anybody here have experience with this? Any tips are more than welcome.
If anybody have a step by step procedure, web link, or whatever..
I was also wondering where to find a machine to do this properly? It seems to be a bit expensive just for 2 or 3 pickup winding.
Thanks a lot
nadege
Stew-Mac sells a winder. I'm not suggesting you buy one, just take a look at it to see what makes it tick. Then, build or modify one. I've seen some that were simply a plywood disk attached to a drill. That might be all you need for 2 or 3 bobbins. Jason Lollar did an excellent book on the subject. Unfortunately, it's out of print and rather coveted.
I've seen people make pickups on a regular vinylplayer. It doesn't rotate too fast and it's easy to setup. 4500 turns takes 1h 40min with 45t/min. Try it! :grin:
Here's the best resource I've found on the net:
http://music-electronics-forum.com/forumdisplay.php?f=11
I've been winding pickups for a while now and I use an Adams-Maxwell industrial bobbin winder, but I wound many pickups by hand (OK, just a few with hand cranking) and using a cordless drill. Even though the AM machine makes winding a breeze and it's much faster, you can get great results with many other cheaper methods.
Don
