(Short version: I'm wondering how to prevent from accidentally frying these devices, as they are hard to come by...they have no output protection.)
Longer version:
Ive been very happy with the circuit below used as a headphone amp and/or hi-fi preamp...this using LHoo33's ( with OPA602 or other opamps).
(btw, the circuit sounded better, with the "Rsc" output resistor...outside the loop, not inside like my schemo/datasheet schemos.)
pic:
http://i5.photobucket.com/albums/y177/Midiot/nonparallelLH0033.jpg
I just recently bought a pair of LHoo63's ($$), and I'm concerned about the devices' lack of short circuit protection.
Does the output resistor in my circuit above act as protection ?
Or should I employ the technique below, as in the datasheet(s) ?
..or is there a better way ?
I want to preserve as much current on the output, to drive my 32 ohm headphones.
From the datasheets:
"" Because of their high current drive capability, the LH0002,
LHoo33 and LHoo63 buffer amplifiers are suitable for driving
terminated or unterminated coaxial cables, and high current
or reactive loads. Current limiting resistors should be
used to protect the device from excessive peak load currents
or accidental short circuit. There is no current limiting
built into the devices other than that imposed by the limited
beta of the output transistors. ""
http://www.national.com/an/AN/AN-227.pdf#page=1
http://rocky.digikey.com/WebLib/National/Web%20Data/LH0033,%20LH0063.pdf
=FB=
Longer version:
pic:
=FB=
